Technical Fiat Panda Cross 4x4 '07: Loud humming from engine during load
BKD
Gothenburg
Tried searching for this, but came up empty handed.
So I'm having trouble identifying the cause of this issue here. In highway speeds and with heavy load (like 4 people in the car f.e.), my 4x4 is making such a noise when putting on the throttle. At around 100-120 kph and 2500-2800 RPM, if I put any amount of throttle I start hearing a loud humming noise that resonates incredibly in the cabin.
Sure, I know the engine is under load and stuff, but the humming really gets so uncomfortably loud that I cannot imagine this is normal behaviour. The sound really fills the cabin to such a degree that I'm having trouble discerning where it could be coming from.
It's Fiat Panda Cross 4x4 with the 1.3 Multijet engine. I know this is a vague question, but I don't even know where to start. Anyone recognize this?
koalar
Distinguished member
Cheshire
probably not from the engine or gearbox
You can normally tell there from the front
Try opening different widows to tell where the sound is coming from
Prop shaft
Centre bearing
Exhaust
Would be my guess
If it’s from the centre you need to get under and give everything a good visual inspection
Then physical inspection.
If you can’t find anything it’s possible to remove the prop shaft and test as two wheel drive.
DaveMcT
Engine have a noise resonance that occurs around the gear shift points. When the silencer internals fail that noise can get very loud.
koalar
Cheshire
Start the engine
Put your hand over the exhaust
Does the pressure build up and can you hear any leaks
koalar
Cheshire
Does your exhaust have a centre box
Might be different in Sweden.
The 1.3 does here in the uk
OP
OP
BKD
BKD
Gothenburg
Thanks all for the replies! Will do a walkthrough and get back with results.
