Technical Fiat panda 1.2 2006 reverse light
Nixon22
Uk
Hey, I have a fiat panda 06 petrol 169
the reverse lights on driver side has stopped working, passenger side is fine.
I swapped the bulb but did not fix it. So I took the working lighting unit from the left and plugged it into the right and the reverse light didn’t work, put it back on left and works.
I’m wondering do they have an individual fuse per light or is this likely to be a wiring issue, the rest of the lights breaks etc are fine.
Due MOT in a couple weeks so trying to sort it out as worries it may fail on it.
Model
Fiat panda 2006 1.2 169
Year
2006
Mileage
79000
Ahh that would make a lot more sense I thought it had two for some reason 😂 deffo feel silly now
Don't feel bad
Quote 1970 The Milwaukee Sentinel
"There is no such thing as a stupid question if it's sincere. Better to ask and risk appearing stupid than to continue on your ignorant way and make a stupid mistake"
I usually replace the reversing light bulb with an LED on my own Pandas, which does give a worthwhile improvement over the standard bulb (which is pretty useless for seeing anything when reversing).
(It's not monitored for bulb failure, so no warnings, and it doesn't flash or light up dimly when off.)
These ones seem to work pretty well
