deeinlondon
I don't drive very much as I live in London - usually it's a few miles drive to the tube station and then train into London.
I find if I don't drive my car for about 2 weeks the battery is flat.. is that normal?
There is no added car alarm and I've installed a cut off switch for a LIDL Made Car Radio so it shouldn't add to the drain - is two weeks too fast?
I checked the battery and it was above 12V and with the car turned on and engine running reading 14V - is that normal? Battery is Bosch from Costco, no idea how old it is - over 4 years I'd say.
I have a CTEK charger and use that quite often, always before a big car journey which isn't very often but now I go camping one every few months and drive about 200 miles round trip. So charge the battery before I head off just incase.
I just found a Solar Charger from Maplins I had inthe loft, bought maybe 15+ years ago for my firs Punto - thinking of fitting that to the car but I read the volts and it was giving out 20V in bright sunlight, is that too high?
I believe I need to hard wire it into the battery terminals as the cigarette lighter is cut off when the key isn't turned. Any tips regarding this? I was thinking about buying a cigarette light extender and then cutting off the end and fitting to the battery with the solar cell placed on the rear parcel shelf 24/7
