Hi I have a weekend 1.6 auto.
Air Con is down.
I had it gassed last year and it still didn't work, the garage tried to get me to have new compressor, laughed at the price more than I bought the car for.
Weather went bad, and hay hoe its now good again.
I have checked it today, the compressor is not kicking in, air con light is on, I'm guessing the gas may have gone, but to save money can I test the other parts first.
I have found the receiver dryer and the pressure switch on top, green connection with 6 pins. How do I test this to see if its working, I have watched you tube and understand the components and principles to test but I cant find half of them.
next
the compressor relay, I have found the box in front of the battery, what am I checking? it has a red and black relay on the left, one large square relay in the middle with an empty space below, then normal fuses in case to the right, and then a large cable connector?
There is no sign of a leak, from looking for old dye marks, they filled it with dye last year when charging.
I just want to check if the compressor is dead, if so I will open the windows.
Thanks for any help.
Will try upload pictures.
Air Con is down.
next
