HI all, newbee here can any one tell me where the slave cylinder is as mine is leaking and i intend to do the job myself?? what is the procedure? pitfalls? bleeding ?? any help please. thanks roadglide. forgot to mention it's a 1.9 elx td saloon.
It's just below the end of the battery, ontop of the gearbox.
I'd reccomend removing battery and battery holder and any air-ducting in the way. Then 2 bolts hold cylinder to gearbox, and the hose screws into the side. Use the bleed nipple on top to bleed the system, check the brake fluid reservoir is plenty full.
