Technical Fiat Linea T-Jet's Turbo-jet Systems one tube broken - How to replace?
Navin Talati
This is from Fiat linea T-Jet 1.4 Petrol.
As per the pictures attached, a small tube is broken.
1.What this tube is for?
2.Can it be replaced? How?
3.It links what and what IS the function of the tube in the system?
4.The tube seems like that of water sprayer tube used for front screen wash. So this type of tube can be replaced with it?
Guidance awaited.
I haven't worked on your model of car, but I suspect it is a vacuum pipe that is attached to a control valve and maybe the opposite end to the one on the inlet plastic pipe goes towards the turbo control.
If that is the case I would not use screenwasher pipe but something more able to handle heat/oil fumes, vacuum and pressure.
Maybe diesel injector bleed off pipe if similar diameter.
