General fiat idea lights wont go off
pavia
when i start my car the lights are automatically on even with them switched off on the stick any ideas pardon the pun
farnboroflyer
Farnborough.
What lights come on?..............side only?, and what happens when you switch on dipped, or main headlamps?.............have you cycled the switch to see if that has a any effect?
Ian
r0r
Had exactly the same problem, well known issue with the IDEA only solution is to change the indicator switch cluster as the problem is that the light switch probably either melts or welds itself closed, and you can`t get just that switch on its own (of course!) Just mind the airbag removal!!!!!
