Hi all.
I have, as many others on the Fiat forum bad working handbrakes on my Ducato.I have changed the rear brake discs, and replased the handbrake cables, and new brake shoes for the handbrake. I follow the adjustment procedure found on the forum, and i am sure i do it correct. when placing the handbrake lever to the 6th notc, and thightning the adjustment nut to 15nm, the wheel won`t move when i release the lever, it is as stuck as when the lever are at the 6th notch. Have anyone else trouble with getting the handbrake to work after using the procedure? thanks
