Basilwatson
Hi all
I have the Model below , a camper van.
Well, not me actually my Japanese friend. Who as you may surmise cannot speak english. So Im doing this on his behalf. The original problem was rough running at Idle. So we replaced the throttle body. Used a tablet and reset the error codes Now, The engine will rev up but wont take a load. ( will rev but as soon as you try to drive away ,,,there is no "power" ) From what I can gather with my bad japanese is that the engine isnt getting enough fuel. 10cc? So my friend is thinking to replace the o2 lamda sensor.
We both are motorcycle engineers but not Ducato mechanics so have no experience with these models
Are we anywhere near the ball park, Is this a common fault, and the P0638 code error message does this give similar symptoms or is it an injector problem ( if so how do we "install" or clean the injectors , we would have to make an install tool ! )
Any advice greatly received ... Thanks in advance
Stephen in Japan
Stephen in Japan
