Hi All,
I'd like to ask your support in the following topic:
Car details: Fiat Ducato 2.3 88kw (year:2011)
Right now I have 2 failure codes in the ECU system:
- P0105 - manifold absolute pressure/barometric pressure circuit
- P0135 - Lamba sonda sensor - (it's totally clear , what is the problem, I have to change --> I'll)
I already replaced the MAP sensor for a new one (Bosch 0281006076). The failure code is same.
I also replaced the Air Mass Sensor (Bosch 0281006048), but the failure code is still same.
I think it's also imporant to mention that, there was a motor renovation, when we changed a lot of things, like: chain, timing belt, bearing, injector, fuel pump, valves, finger follower, cylinder head renovation, all gaskets. All of them are new , and still quite weak and there's a big smoke.
Currently I don't know what is the issue. If you have any idea, pls give me advice, what cause this problem.
Thanks a lot.
Thanks a lot.
