Hi all
Basically I've just bought a fiat coupe 20v turbo like a week ago and the front driver side indicator has stopped working.
I've done the following to try rectify the problem to no avail:-
Changed the bulb
Used other side indicator bulb
Tested for continuity in the wiring from the bulb holder backwards to near the timing belt cover-all good
Tested for voltage with hazard lights on-getting voltage on both sides the same voltage goes up and down with hazards on
Swapped the indicator bulb holders over and both work in left indicators but both bulb holders won't work in driver side.
Scratched the metal contacts inside the bulb holder and also sprayed electrical contact cleaner but still not working.
I have done every logical thing I can think off and just can't seem to get the front right indicator to work. The other day I noticed it wasn't working so when I slapped the front bumper it came back on so I thought there's a loose wire somewhere but now I can't get it to work whatsoever. I've tried slapping the bumper again but it's not doing the job anymore
If anyone has any ideas please let me know as I'll be driving around with no right indicators until I work it out.
JBSpinThatCoupe
Changed the bulb
JBSpinThatCoupe
