Hi, Could a moderator confirm my upload of the official fiat manual for this gearbox was sucessful and it just needs to be released by a moderator?
I did the upload about 5 days ago for the Palio section.
The instructions and parts in the manual are however more or less identical to a punto gearbox. The only difference I found were:
1. 2004 1.2 16V Punto has needle bearings under gears 1 and 2 on the output shaft,
2. There is no oil centring device for the output shaft fitted to the casing and there is no oil way in the output shaft
I have not yet taken the differential apart.
Basically the manual is a great guide for many of the gearboxes found in various fiat cars.
There is a typo in the manual where 'caulking' is used a few times where presumably in all cases 'staking' should be used.
I got a full set of 'Fiat C514.5' gearbox and differential bearings and seals for my punto from onestopgearbox.com. For the gearbox there are no difficult adjustments or shims required. You just need a cheap small bearing splitter and a cheap 6" puller with diy extensions of about 4 inches. I used sections of a chain to extend the arms. None of the pressed on parts were on very tight with the exception of the roller bearing on the output shaft. My DIY extended puller got it off with no problems though but even with the freezer and the oven I still had to pull the new bearing back on the shaft. For safety reasons when pulling it off you need to cover the shaft and puller with rags to protect yourself from something breaking and exploding into your face.
