Technical Fiat abarth 600 ( Replica )
continuing the shaft bearing support
and
I'm looking for an alternative engine for a fiat 600. It's been 25 years since I fully restored my first goat 500 I'm oz, and I'm doing one in Sri Lanka now but need a reliable engine. Or are there modifications that can be made to the existing engine to improve reliability. Please help. Thanks
hello friends
continuing with the brakes
the caliper are fiat 124 front and rear
Hi Diluppo,
I swapped over to 124 calipers on my 850, and had issues because the calipers are wider than on the standard 850 coupe. Although the disk rotors are interchangeable between 850 and 124, the pads on the 850 are significantly thinner. The problem occurs when you put the car on the road and turn the steering wheel full lock in either direction, the upper control arm interfered with the brake hose. You definitely don't want your hose whacked by the control arm!
My solution was to relieve the control arm locally and reinforce behind it to ensure that the arm retained strength. I also changed the brake hoses to a male screw thread so they screwed directly the caliper.
Cheers, John
Greetings friends
Estimated sr: Jajarr JOHN
I really had no problems with the brake calipers front of fiat 124
use brake hoses fiat and made the threads in order to fix it in the original position of 600.
Annex photos.
Hello Friends
Returning forum
thanks for the comments
Now we see the pipe to cool the engine coolant
ahora revisando ,limpiando y restaurar algunas cosas
door locks
mechanism raises glass
stop lights
Incredible work man. Truly exciting and I'm looking forward to following along. I just got my hands on a '64 600 and a five 903cc engines and will be doing the swap plus extensive body widening and air-ride, which will be interesting, LOL!
Can you email me a few pictures of the Abarth radiator shroud you built?
Regards-
Jason
[email protected]
Thanks to all friends
we continue with more of the replica abarth
I will now make the support of the new dashboard clocks
with little money can do
and visiting scrapping cars
watches buy a Lada Niva
Redraw the faces
Continue to Work
It was not broke the dashboard, just two holes were made to fix
finished fiber part
was given a painting
Hi diluppo
Only just found this thread, just have to say what an amazing job you are doing, thanks for the pictures and updates.
