Technical  Fiat 850 gearboxl
I used to identify the 850 Sport Coupe by the presence of a reverse light/lamp switch, I don't remember the Saloon or 850 Van/Familiare having a reverse lamp (I do seem to recall the 850 van had a lower final drive ratio inside the gearbox(.
Hi how do I identify a 850 coupe sport gearbox is there a specific serial number cost on the housing thanks in advance
There was a red or yellow spot of paint applied by Fiat to the upper center area of the bell housing or around the gearcase vent which would indicate it had an 8/39 (4.88) final drive gear set (ring & pinion) inside, as used on the Spider, Sport Spider, Racer, Coupe & Sport Coupe models.
Of course, this paint may be gone if vigorous cleaning of the transmission has been done. At that point, removing the bell housing & looking at the info stamped into the beveled edge of the ring gear is pretty much the only option left.
The reverse switch was the giveaway for me too.
There's no difference in ratios between the coupe and Saloon is there? I've a couple box sitting in the garage and I'd do a swap if there were a few less rpms
I knew someone who rallied an 850 Coupe (back in 'the day'), he fitted a gearbox from an 850 van, which had a lower final drive ratio than the Saloon or Sport, iirc it did c. 80 mph @ 8,000 rpm in 4th gear (i.e. c.10 mph per 1000 rpm in top gear) - so you certainly don't want to use this 'box if you want lower revs for a given speed.
