General Fiat 500 Pop 2013
Alvin Saxophone
Blackpool
Fiat 500 Pop 2013. Stub radio aerial PCB. There is a small circuit board ( PCB ) located in the base of the stub radio aerial. Does anyone know what its function is ? Mine went faulty, so I bypassed it and the radio now appears to be working as normal.
I dunno if the PCB is a signal amplifier/interference suppressor.
If you have your radio on next to a petrol lawnmower, that might prove it..
Ralf S.
Ralf S.
Hello Ralf S.
The possibilities that I can come up with are are : RF Amplifier, Interference Suppressor, Filter circuitry ( ), Impedance matching circuit for the aerial to facilitate AM and FM reception from a small aerial. And finally, a lightning discharge device. Like you suggest, I'll have to wait until an un-suppressed sparky device is being used near to the car. Trouble is....most modern petrol lawn mowers will have good suppression built in. I am just very interested to find out what that PCB actually did. Volume setting on the radio remains the same before and after removal of the PCB.
If it has power, it's probably a amplifier otherwise a filter system?
Hello John,
The PCB has active devices on the board, so I guess power is fed up the aerial coax cable to the PCB. With the coax open circuit at the aerial end, I could not detect any ac or dc voltages on the line. Might be different when the aerial line is terminated. Currently, I would agree with you. Thanks.
