Technical Fiat 500 dualogig
Maisydaisy
Berkshire ks
Has anyone had problem with fiat 500 dualogic in autumatic when start in morning it can't get into gear properly and keeps jumping.. Has got worse over 8 weeksReverse is same. Fiat diagnostic couldn't find problem.. Only happens when car is left a few hours.. After driving 15 minutes it's fine
OP
OP
Maisydaisy
Maisydaisy
Berkshire ks
Hi :)
Is the car setting off 'jerkily..' or actually jumping out of gear?
How long have you had it..
Been ok for thousands of miles..??
Its in automatic and when turned on is jerky or stop at junctions or if put it in reverse its the same until have driven for 15 mins.. 3 Yr old 6400 miles
Near the M4
Sounds like ' the Robot' isnt controlling the clutch very well
Commonly caused by low fluid.. it then will need any air bled from the system..
To restore proper Robot function
and potentially a Relearn of the Clutch 'bite point'..as it appear this has been happening for weeks
Search
'Selespeed Fluid' on here :)
OP
OP
Maisydaisy
Maisydaisy
Berkshire ks
Search
Omg.. Thanks for your help I will tell fiat garage as they didn't know 😳😑
Near the M4
Sounds like you want to try a different garage..
Did they charge you @£100 for 'Diagnostics' ?
Thats not unusual for a main dealer..
Just about ok if they get to the bottom of a problem.. a waste of your money if they dont (n)
Where are you based..?
Somebody local might have a recommendation :)
OP
OP
Maisydaisy
Maisydaisy
Berkshire ks
Yes they did.. And said car was fine. They said I was out of warrenty by 6 days.. But spoke to complaints yesterday and might be in by a day or so.. They will come back to me nxt week. I'm nr Reading Berkshire.. Thanks
