Faulty RPM Meter ( Mk1 HGT)
B
Boorock
Guys;
My Mk1 HGT's RPM Meter has a problem...
It comes & goes ramdomly...
The electricians tried to solder the inputs ( thinking that the socket is the problem) but they failed.
It simply goes of without reason & when I hit over the dash, it comes back... ( Most of the time..)
It's very annoying...
There seems a connection problem "inside" the tachometer/dials :(
Any ideas what to do for ?
I've seen some prior posts about changing the bulbs with LEDs or changing the dial face but they are not mentioning about any connections inside the tacho ?
If I decide to open the tachometer, where should I have to look, what to repair for ?
If I deceide to open the tacho, I may change the bulbs & the dial face but first I need a working Rpm meter :(
Any ideas ?
Thanks in advance :)
id get yourself a new pair of clocks.
easier option.All my needles just all of a sudden stopped working,replaced with new clocks and all is well :)
Mike
A Fiat Marea in a Bravo Shell..Its good to be different ;)
Now with Working Steering Wheel Controls :)
and fully alarmed up!
F
7K
F1-ANG
F
A
1
11K
Angelo
A
M
418
M
1
7K
Dark Lurker
