Pete145
- Joined
- Jun 2, 2014
- Messages
- 288
- Points
- 85
Hi everyone,
I, like a lot of us here in the UK, keep my car running through the winter as much as possible. However it's not often that I drive in the dark. I did so recently (for the first time in ages) and I've noticed a fault with the rear lights/brake lights.
When the lights are off, the brake lights operate as they should. No problem. However when the lights are on when I apply the brakes the rear lights seem to switch off as brake lights come on, and then return to normal when I stop braking.
I assume that this is a pretty simple issue to fix, and that the lights might just be wired up incorrectly?
Over the last few months my horn has stopped working (no obvious visual issue) and the dashboard light (it's a Lusso model prior to Abarth 595 style of conversion) has not worked since I've owned the car, despite the bulb being changed, and the interior light switch has also been missing since I've had the car.
So, a few electrical gremlins to fix before the next MoT, specifically the rear lights/brake lights and the horn.
Thinking bigger picture for a minute, when I stop and think about it the car's now 46 years old and, as far as I can tell, it still has the original wiring. I've had an alternator fitted, and I know that wiring looms can be replaced (albeit a time consuming exercise), but has anyone ever gone the whole nine yards and completely modified the electrics on a 500 with a modern, more reliable set-up (not just replacing like for like)?
