G
Gary F
Got my car serviced this morning at the AA and it didn't go well
List of problems
0SR shoes worn down to the metal
OSR drum scored and lipped NSR lipped
Front brake pads on 2mm
Front brake discs below minimum thickness
middle of exhaust split and front exh gasket leaking
brake fluid below minumum boiling point - 118oc
No 2 plug lead requires replacement
no spare wheel on vehicle.
OK so the AA said to fix this would be nearly £800, my dad thinks this is excessive, is this right? Plug lead and gasket are quite cheap, no?
So, the brakes. Do you think it's worth changing the front discs and pads and rear drums and shoes all at once?
If so what would you recommend? All I want is to stop quicker, I am not bothered about dust on alloys etc.
Also what about the exhaust? I haven't had a look at it so I don't know where it is split, any ideas, cost?
Might have to go to powerflow.
Thanks in advance
Gaz
Cars a 1.4sx 1996 Bravo
PS I don't intend to get any of this done at the AA
PPS it says on the service sheet they hoovered the footwells, did they fcuk lol.
List of problems
Thanks in advance
Gaz
