General fag lighter
General fag lighter
charlieboy
Prominent member
east mids. derby.
i curently dont have a fag lighter in my uno, how can i get one? install it so that it works preferably (not that i smoke!!!) just there are mautiple things that work off it and it may be helpful to have a working one lol
cheers charlie
Find a uno with one and remove it, there's a black (?) weird plug behind the fuse block, (check doing voltage check and removing the fuse) plug in = sorted.
I wanted one too (not a smoker but needed for various devices like yourself). I got one from another car and used it but still used the correct plug and fuse :)
They are likely to be made illegal soon (ish) though. Also, I expect with these "you get what you pay for"
To be fair they do work. Well can't speak for all of them but the one I've seen (road angel I think) works really well, gives you good warning of when one is coming up as well as a few accident blackspots even where there are no cameras.
As for the power socket if you can't find one there just buy one from Halfords (I got one under £5) and stick it in... erm can't remember where I wired it to but obviously you have to search for a suitable wire.
there are multiple thing which work off the fag lighter anyway so it would just be handy to have it working, if you get where im coming from ?
gonna try get it working l8a (drive ways full at the mo :( )
Dont you have a mount in the top centre console that flips up thats got the mount and the ashtray?
Punch out the blanking plate and wire it in. If you dont have a plug there (dont think mine did) the brown wire is the constant 12v power supply... (i wired my headunit off this too).
Yep, it mounts there, BUT if you intend to use it for devices I would mount it elsewhere - it looks better and you don't have to have the flap constantly open showing off the ashtray.
the plugs that fit into the faglighter space are small enuf to shut the lid agian so that it is just a wire showing i think, not too sure, if it doesnt it should close half way-ish lol
Mine multivoltage plug was large so the lid wouldn't close, if I was doing it again I would have mounted it behind the radio on the plastic section there.
Not saying you need to of course, just suggesting :)
