English Gent
Hello everyone, I'm here to seek the collective wisdom of the forum..
I have a 2006 Fiat Panda 4x4 with the 1.2 petrol engine. Ordinarily I don't do a lot of mileage, so it was little more than 5 miles to the shops and back once a week, but now I have to go further, occasionally crossing the High Peaks between Manchester and Holmfirth and beyond.
On a previous return journey, the car was working hard to climb up from Holmfirth and when I started to effectively coast down hill with the car in 5th, the engine warning light came on and the water temperature gauge went to Cold. When I started to actually drive the engine along the flatter roads the temperature needle jumped up in two or three steps to the normal middle of the gauge area.
I booked the car into a local mechanic and he said the error code was for the temperature sensor which he changed (along with a service, cambelt and water pump and spotting the cause of a 'clunk' in the drive train I also mentioned - engine mount and rear differential bush had collapsed)
I had the car back after the repairs and took it a few junctions on a motorway with no problem. Then out across the moors again as far as Rotherham with no issues, until I came back towards home and the same thing with the temperature gauge going to cold and the engine warning light is on again as I started coming off the moors! The gauge started with a bit of a jump up to the middle again once I started to use the throttle.
Typical of my luck is that the nearby mechanic is on holiday for a couple of days.
I'm thinking perhaps the thermostat is sticking as it's working hard and then suddenly coasting downhill at speeds of 40 to 50mph causes the pipe where the sensor is to empty?
Any guesses? Anyone had the same thing?
