i have a 53 reg punto mk3 1.2 8v. i want to tune engine up can i get a turbo and how much will that cost what else can i do. i want power out of the car.
Well, considering the Punto HGT engine is near enough the same as the Coupe 16v, it shouldn't be a problem but then add the turbo and you might have problems as the HGT is very limited for space under the bonnet
the 1242cc 8v and 1242cc 16v share the same block dont they. So mounting wont be a problem. Problem you will have is the ECU/loom etc will need changing when you do the swap iirc.
120bhp from an NA 1242 8v, wirly - you have pm, lol!
