Hi, been reading some of the postings in relation to engine temperatures and i think people need to remember that a petrol engine is at its most efficient at high temperatures. The temps on the guages (and there are probably differences between gauges on different cars) do not mean that your coolant is boiling or anything like that unless it goes well into the red. The system is pressurised and will only start to 'boil' about 130 degrees Celcius or thereabouts. In a pressurised system the water is not boiling at 100 C, 110 C or anythign up to about 130 C. While 130 is high, the normal (optimum) operating range should be between 90 and 110 degrees C. The system is pressurised to allow the water to boil at a high temperature - it has been designed like that by FIAT.
A car that is running with a low normal operating temperature will not be particularly efficient on fuel, plus the oil never gets a chance to thin and will be like sludge chucking round the engine putting stress on internal components. A normal operating temperature below 70 C will not be thinning the oil very well. Image if all you ever did was cold starts - thats what an excessively cool running engine will be like, stressing away at the insides of your engine.
So a too hot engine is bad, so is a too cool one.
teach physics at university
