Hi everyone,
I bought a 1.2 punto mia with approx 60,000 miles on the clock at the end of September, and with the exception of needing a new coil pack, it's been a great little runaround.
But recently the car was left for a few days buried under snow in freezing conditions. It needed a jump to get it started, and made some knocking noises at first, but these soon went away. But then as I was driving it a day or so later, the engine started to shake quite forcefully when I wasn't applying any gas, the temperature light came on and white steam/smoke began to come out from near where the oil stick is and there was a smell of burning. The car also stalls sometimes in idle or a low gear and will only start again if you leave it a few minutes. The heater can blow hot air, but only rarely and unpredicatably. I'm pretty sure it's not the head gasket, since there is no 'mayo', no coolant leak, and the exhaust gases seem normal.
Obviously, I'm not driving it anymore until I can get it checked sometime this week but I just thought I'd ask here and see if anyone had any idea what could be the problem. Cheers!
