General engine no/code
Sammii
Hey, doing a top end service on my cinq, gaskets, stem seals etc, but to order the gasket kit i need to know the engine code, as apperently there are 2 and unfortunatly my vin plate is worn and cant make the engine no' out...
FIAT
CINQUECENTO
170A1-000
899
8
1994-1998
FIAT
CINQUECENTO
170A1-046
899
8
1994-1998
Mines a P reg Cinq 899cc SX, will it be a 000 or a 046???
thanks
engine code number help?
FIAT
CINQUECENTO
170A1-000
899
8
1994-1998
FIAT
CINQUECENTO
170A1-046
899
8
1994-1998
thanks
Re: engine code number help?
OHV engine specs and torques
  • Engine code 1170 A1.046
  • Capacity 899cc
  • Nominal bore 65.0mm
  • Stroke 67.7mm
  • Compression ratio 8.8 : 1
  • Max power 29KW @ 5500RPM
  • Max torque 65NM @ 3000RPM
  • Firing order
  • 1-3-4-2
  • No 1 located at timing chain side of engine
Is that the right bit?
170A1.000 is a 903cc carb engine
170A1.046 is a 899cc SPI engine
There is also 1170A1.046 which is also a 899cc SPI and also carried on in the Sei
My 1994 Cinq is a 1170A1.046
thank you mate, mine is 899cc, lol, tiny little thing.
cheers people
Goodevening lads,
I’ve got a question about my engine, it’s code is 1170a1.046, but I want to replace my headgasket, since it’s leaking oil and I want to know if it has rocker valves, or a more common and traditional system with a camshaft?
Thanks in advance!
Goodevening lads,
Thanks in advance!
It is an OHV engine.
The camshaft is low in the block and activates the valves via pushrods and rockers.
