I an unable to fully tighten the bolt on the engine mount drivers side it's not loose but as i tighten the bolt it just turns, there is no way of getting to the top as the bolt goes upwards through the rubber piece, is there a threaded part that the bolt screws into inside the mount!! if there was a nut at the top i could mabe get a spanner on it as u can get your hand up to the top next to the alternator ,does this mean something has broken or come apart, is there any way it can be tightened , i have tried jacking the engine a little to see if it is easier with the weight off the mount but still the bolt just turns, it does feel as if there is some movement more so when reversing, many thanks.
