2002 registered Ducato version 11 JTD 2.0 litre. Intermittant fault. Injection system failure light comes on and engine power reduced - . Can't see any pattern to the problem except more common on long journeys. Usually when going slowly around bends.
Van taken into garage [ Fiat dealer ] several times. Tested with Smart Examiner. Came back with fault P0220 - fault in accelerator pedal sensor number 2. Have changed pedal and cleaned up wiring contacts. Fault not resolved. Recently a new fault code has come up P0219 - probable causes wiring or connections faults, rpm sensor or injection control unit. Garage does not seem to know what to do next. Any ideas ?Fault numbers 219 and 220
