Technical  Engine management light
Mully1971
First of all I'd like to say a big high to all the fiat forum users ,and thank you in advance for any help you can bring to the table (y)
I have a fiat fiorino multijet ,from which I have been told is the same as the qubo ,
I did the utmost sin and panic bought it 3 years ago,and have had nothing but problems with it from the day I have bought it ,I've had to throw another £600 at it and we still haven't solved the problem,
At approx 3k revs or 60mph the engine management light comes on ,and it goes into limp mode ,
We have changed the maf sensor,the egr Valve ,which is what I was advised to do but still having the same problem,
Does anyone have any other ideas ,bar that it needs a whole new turbo as we are trying to eliminate all the smaller things before we go down the heart crushing cost of replacing the turbo ,as I have thrown so much at this vehicle that it would be admitting defeat :(
Many thanks in advance !
First thing you need to have done is a code read , record them , clear them road test then re-read ,once you have the current fault codes they can then be correctly diagnosed , remember never change a part on a code alone it's only points towards a fault in the circuit ie open or short to ground or positive or signal above or below peramiters , will be happy to advise on test procedures etc when you get the codes out of it ,
I had this on an Astra a few years back. Had the ERG changed etc. Made no difference, then an old mechanic told me to put Redex in. Never had the problem again!
Hi. Is the issue still there?
Who does the oil changes..??
Charlie
