PaddyPanda
- Joined
- Jan 14, 2017
- Messages
- 5
- Points
- 1
We have a 2009 Fiat Panda 1.1 Active Eco has a recurring problem that the Engine Management Light Flickers for a second and the car looses power for an instant. This first happened last summer and appeared to happen when going over speed bumps. The problem re-surfaced in the last month and in addition the engine cuts out completely when driving, even very slowly, over our lowered kerb into our drive way (happens as soon as the driver tyre hits the kerb). An independent garage service the car (new plugs etc) and check for registered faults and found nothing. As the revs at idle (too high) have been an ongoing problem that no-one could address for me, I took advantage of a deal and replaced the throttle body and both coils and put new spark plugs leads in. I also removed all the electrical connects cleaned and reconnected them. I also checked that all the fuses were properly inserted. Although the car no longer cuts out, the Engine Management Light and loss of power still happens going over bumps. The Fiat dealership want £600 to trace the fault through the wiring and an auto electrician has quoted me £50 + vat per hour. I'm going to attempt to trace the problem which now sounds like a wiring problem down the loom. Any advice on how to tackle this methodically or known areas of weakness to start the search would be very much appreciated. Many thanks
