Hello,Got the car back, eventually. Supposedly one of the sensors was faulty. Anyway, I've done a few runs in it, and it's not had any fault lights so far. Hopefully that's it fixed now.
Lambda failure is only a result of running too long with poor spark plugs. It looks like that the dealer doesn't automatically change the spark plugs each 18600 miles (30 000km). It takes a little more miles to get a misfire, but why even wait for the fault code to show up. It has already damaged the cat and the lambdas by then. The wrong fix is to ignore the plugs and clear the code and just keep driving.
I replaced both lambdas, ignition coils, put on new spark plugs, replaced the mapsensor and cleaned the throttle body. Unfortunately, the error still pops up ... I looked with the inspection camera inside the catalyst and it seems to me that it is clean. Unfortunately, everything indicates that it is a catalyst.Other than replacing the lambdas, has anyone actually got a definitive cause for this? I have 2 Tipo's, both 1.4Tjet Estates, both with EML's on with the same fault. I have replaced the spark plugs and a degraded breather hose that leads to the inlet as it may have leaned out the mixture. Every time, the EML comes back on on the first drive afterwards with the same codes relating to the Lambda's. I've looked at some live data while driving and there's not a lot of drift in the signal so I'm reluctant to change the sensors out if they are just indicating an issue elsewhere.
The tipo has be out since 2016 I'd say most of the cars made are now out of warrantyWhy change the map sensor? Did you buy genuine Bosch sensor? Are Lambdas Bosch too? Other brands don't work so well.
Probably nothing wrong with the sensors. Hard to tell you could list all the current codes.
Also keep in mind that after changing the sensors, you also need to reset all the trouble codes.
It's quite a new car still. Shouldn't you be taking it to a Fiat garage? It may be an intake manifold leak if there's a fault code for MAP sensor.
I tried to clear the P0420 error. No other errors. All the things I replaced came from a friend's Tipo which don't have any errors and all was original parts. After replaced i reset the trouble code.Why change the map sensor? Did you buy genuine Bosch sensor? Are Lambdas Bosch too? Other brands don't work so well.
What date of production are your tipo's? I heard that the end of 2017 and the beginning of 2018 had some faulty catalysts... my is 12.2017.. so mby that is true.I replaced the breather hose that passes through the engine cover and heads down to the crankcase as they were badly deteriorated / cracked and leaking, but that didn't solve it either unfortunately. I've got an MOT coming up in around a month so I'm going to have to spend a bit more time trying to resolve it as any EML is an instant fail now.
They are registered 2017 & 2018 but not sure of date of production. I'll check it again at the weekend and see what codes I have now. I think my code was the pre cat lambda iirc so if that is the case, it shouldn't be the cat hopefully. I don't do service centers, always do everything myself wherever possible.What date of production are your tipo's? I heard that the end of 2017 and the beginning of 2018 had some faulty catalysts... my is 12.2017.. so mby that is true.
