Hi there,
We picked up a 2017 500S 1.2 almost two weeks ago and have had a couple of limp mode issues, the first one on the drive home.
The car had a service with cambelt/water pump before we collected it and was running perfectly when we left the dealer.
On the drive home from collecting the car it went into limp mode with the EML flashing. Pulled over and switched the car off and on again and it was fine and has been until tonight where it did the same thing again. Car off and on again and seems fine.
I have a scanner (£25 off Amazon) and there are no codes stored.
I did the phonic reset but the car was running fine at the time so not sure if it was successful or not. I replaced the spark plugs at weekend but the car ran perfectly before and after this and has done until tonight.
The only slight thing is that when pulling away from stationary it seems slightly hesitant just as you set off. No spluttering or misfire, just a slight hesitation. Hence changing the plugs. We also have a 2010 1.2 Pop that doesn't do this.
We bought the car for our daughter so I need to get to the bottom of it really.
Car has done 60K miles.
Thanks in advance.
Stevie
Thanks in advance.
Stevie
