Technical engine identification
davidboris
hello folks, i was wondering if someone could enlighten me as to which engine i have, it carries the following marks. Cast on top ak84m 650 and stamped on the flange the number 9743356 thanks in anticipation.
Hi David , what you have there is one of the later 126 engines with the unleaded cylinder head , improved combustion chambers and higher compression ratio so they had a slight power increase on the earlier 650 engines so if it is in good condition you have done well there. I have just this minute got back from the post office sending off one of those new heads to a specialist to be ported/gas flowed after I had already had larger inlet valves fitted. The original 650 heads just have the 650 on the casting.
