Not sure if this is a new one.....
on the way to work this morning, drive 2 mile then beep beep beep.. engine fault.... car still running fine, seems no different at all,
thought it might possibly clear as fiats usually do this .
but no !! every time i start now it flashes engine fault and the amber engine light stays on, but the spanner dissapears once it stops flashing engine fault.
car still runs fine,,, well appears to, never stalled..
dropped it in for diagnostics at a local non-fiat garage, faults showing fueling imbalance and map sensor fault... but it still runs ok????
tried disconnectin battery for 1.5 hours to try the reset and cleaning map sensor conns and even took out the sensor to check it over, had a look at the d4 seemed fine and did checks on lambda and throttle body..... im now stuck...
still pops up engine fault.... but doesnt say stop engine..
and runs ok.... possibly a little rich.
any advice greatly apreciated... pulling my hair out i am!!
