engine cuts out
engine cuts out
C
chris
can anyone tell me why my 1.4 brava cuts out every now and again when im at lights or in traffic? not often but annoying,if i put revs on all day it does not happen?
thanks,chris
has been ok since start off year but started around same time i had ecu fixed 4 month back,1 of down sides was the immobaliser system had to go to let it work, could it be anything to do with that? even after i had it done the injection light still comes on now and again and gives you a good throw back into your seat!!
someone said reason it cuts out is cambelts going? then another said you would not know until it just went?
Had same prob with mine, heard if you change spark plugs, oil an stuff it healps, sme one correct me? I havnt done it yet.
Seb - Brava 1.4sx
ok i serviced the car on sat running a lot better now the plugs and oil that i have taken out were bad:(
it has NOT cut out since in traffic or at lights :) and wile i did the service i also filled the tank and added some gas treatment to the fuel the injecter light has not come on at all so im very happy
I
2
747
Dark Lurker
630
David
T
1
283
Dark Lurker
S
193
sly si
S
