taffyboy66
59 plate petrol grande punto 1.4 active. Eml light on and codes read as follows. P0300 random/multiple cylinder misfire detected.
P0121 throttle/pedal position sensor/switch A circuit range/performance
P0221 throttle/pedal position sensor/switch B circuit range/performance
There is no misfire and the car is running as normal. I have taken off the throttle body and cleaned it up, no difference eml still on. I have cleared the codes but the light comes back straight away. I have purchased a new throttle position sensor but the one sent has a 3 pin connector and the one which I believe it to be on the actual throttle body Is a 6 pin connection. Any further help advice is very much appreciated
