Hello folks, so the Sei failed miserably on it's emmisions, CO was off the scale and HC was three times the limit, Lambda was at 0.65. When I had a look round the TB I noticed the fuel return pipe was broken off completely. I don't think it could've been like that at the test (pretty sure they'd notice all the fuel pissing out and fail it for that) but it could easy have been weeping, I fixed that, but she's idling rough as dogs nuts now, sounds like it's misfiring.
The head was recently swapped for one from a Punto 60 and there's no signs of HG failure, comp test was even across the cylinders last time I checked, I don't think it's that, but the exhaust does smell a bit of burnt coolant, took her for a run to let the ECU relearn, I just fitted a chip, I can't really tell if it feels down on power since I haven't driven it for so long, felt a bit gutless at high revs, but I've been driving a Celica 190 for the last while so I suppose it would.
Any suggestions? I'm thinking of getting an OBD reader from ebay to see what codes come up, or start changing every sensor on the engine. I checked for spark tonight and that seems fine, no1 was maybe a little weak.
