Hi , I have a 2003 punto the windows have never failed on me , last night the window went all of the way down with no trouble but woukdnt go back up , I took the door card off , wd40 on everything and all was ok , tested it for a while , all good , I then replaced door card and same again ! , if i slam the door or hit area where motor is then it starts up again , It goes up and down no problem , also closes without issue., however if you open it fully it gets stuck , also motor although smooth and quiet got very hot , can anyone offer a solution to this , thanks
