Electric spray Guns
Electric spray Guns
dave
Essex/Suffolk border
they not realy good enough for a car. get an old fashion hover that blows as well as sucks an make a compressor out of that
OP
OP
Noclu3
Noclu3
Fiat = Ticking BOMB!
North Essex
I saw that and wondered if it was just gonna be crap?
Do you recon its work £50?
a1ant
-~Moderator~-
Staff member
UK
That compressor will do the job. As dave said, the electric ones arent really up to giving you a qulaity finish like that you need on a car.
West Yorkshire
our machine mart over here always have clarke air compressors in their used/b-grade stock, all with warrenty. you can easily pick one up for £50 and no hassle should you have any problems with it (y)
i assume most machine marts will have a b-grade section like this.
Tris Harris
Top Dog
Leeds/Whitley
wheres the machine mart in west yorkshire?
dave
ah yeah my machine mart has a corner or returned open boxed stuff as well, got my racing jack it there for nearly half price :slayer:
don't forget you don't need no big massive compressor for spraying as you only need low pressure
OP
OP
Noclu3
Noclu3
North Essex
Thanks guys.
I missed that last compressor (went for £65 all in)
Looks like the seller has loads though.
bridges
Here to help
Lincolnshire
Yes. As spray guns run usually between 30-50psi which can be provided by a small compressor. However you dont want your compressor to loose pressure half way through a panel. Tank size is critical. This compressor would not hold enough pressure for a bonnet if the spray gun was at 40psi (n) For small areas though it would be ideal and will be a million times beter than the electric variety. (y)
OP
OP
Noclu3
Noclu3
North Essex
What tank size do I need to do a whole bonnet or roof?
I have a entire car to do, bit by bit.
a1ant
-~Moderator~-
Staff member
UK
25L tank will be fine. It should have an auto start function that will keep the tank topped up whenever it falls to a certain pressure. As long as it has a high enough displacement (the amount of air the motor can supply on its own) and you set the auto start/stop to say at least 50psi (most on that thype of compressor are about 100psi by deafult anyway) then you shouldnt have a problem.
bridges
Here to help
Lincolnshire
A gravity fed spray gun uses I think 150-180 lt/min. Therefore a 25l tank will struggle with a bonnet/roof purely because the compressor will struggle to compress the air and fill the tank in the time that you are emptying it. ;)
I would be looking at 50l as an absolute minimum. :)
rpaterson
Ayr, United Kingdom.
I'm looking at getting a compressor for Xmas. i was looking at one in Screwfix for £130 with a decent displacememtn and I think a 50 litre tank. Accessory kit was £20 on top of that for guns, inflators, hose etc.
Will now be checking out 'B' grade stuff though :)
rpaterson
I'm looking at getting a compressor for Xmas. i was looking at one in Screwfix for £130 with a decent displacement and I think a 50 litre tank. Accessory kit was £20 on top of that for guns, inflators, hose etc.
