Hi there, just purchased a 57 plate scudo 90 multijet van,
a couple of things I would like advice about.
Firstly the main issue is the electric windows have stopped working apparentely the morning I got the van, the switches light up as normal and when you press the switch you can here a faint click from the winder motor but nothing else and this is both sides. When I picked it up the guy had washed the inside with water as he is a builder and there was a lot of water around the battery compartment, could he have shorted something out in that area?.
Secondly when engaging 1st gear there is a bit of a clunk noise is that a problem?.
Any advice on these matters would be greatefully received.
