Well, I've just replaced my EGR valve and cleaned the old one up.
For cleaning I used diesel fuel but I suspect that parafin and possibly brake cleaner will be OK.
Now for the puzzling operation details/questions.
When I split the old valve, solenoid from valve body both the valve body valves could easily be moved/depressed and returned OK to the sprung closed position.
The solenoid plunger, standing about 5mm proud of the housing, with a spring tension a little less than that required to move the sprung valve rod, could easily be depresssed into the solenoid housing. Using some grips and protective rubber I could NOT extract the solenoid plunger any further than it's 5mm rest proud position.
Connecting the old solenoid on its own and running the engine, or using FiatECUScan to activate the solenoid the plunger did NOT extend, however I could not easily depress the plunger.
So this makes me think that the solenoid is used to lock the valves in a closed position and that the EGR flow is based on positive exhaust pressure forcing the valves open unless they are positively held closed.
Any comments out there?
