ECU resetting, again.
J
John
I know this has been posted a million times but,
Do I need to remove both the terminals or just one?
Cheers
John.
Re: Re: ECU resetting, again.
Which one Tom. I think it would be the positive because the negative doesn't do much. But I'm just checking.
Re: Re: Re: ECU resetting, again.
They both do exactly the same amount :) Remember, its a circuit so has to have an in and an out. Disconnect either and it stops.
Just remove the earth wire and leave it overnight.
When disconnecting the battery completely you MUST always disconnect the earth terminal first. Its a safety thing.
Re: Re: Re: Re: ECU resetting, again.
I've been looking through the Haynes maunal and the Fiat Bravo Ovner Handbook.
One of them (can't find it now to quote it) goes on about driving for about 15mins at different speeds and in particular 2000-4000 rev range.
Then letting it idle for 10mins while occassionaly turning the steering wheel and turning on power using things like the rear windscreen heater.
Is this all really necessary?
Re: Re: Re: Re: Re: ECU resetting, again.
Considering the ECU does not go into learn mode for about 20 mins, both of those are pointless.
Just drive normally and it will re-learn over the next few hundred miles.
Re: Re: Re: Re: Re: Re: ECU resetting, again.
Thanks a lot Tom.
John.
Re: Re: Re: Re: Re: Re: Re: ECU resetting, again.
Whenever we remap an ECU, we start the car and allow it to idle for 5 minutes before driving or even revving. This is the same as when you are reconnecting the battery as it allows all the positioners to settle and give you a fresh start.
Its either that or Andy just likes using it as an excuse to have a ciggy after doing the job and before we drive the car lol!
Nige
Re: Re: Re: Re: Re: Re: Re: Re: ECU resetting, again.
Folks, having just bought a Brava, would it be worthwhile resetting the ecu? This self-learning ecu, it learns your driving style and adapts accordingly, right?
Re: Re: Re: Re: Re: Re: Re: Re: Re: ECU resetting, again.
Oh dear I've started it all agian.
Tom will tell you better but it resets all the settings and allows the ecu to start again and adapt to the surrounds and ignore the settings you don't need for the British environment.
Close enongh Tom?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ECU resetting, again.
I did have a look for a search function, but I can't seem to find it. Sorry about this if you've gone over it all before.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ECU resetting, again.
ITs nowt to do with driving style, it learns the engine.
7
848
S
G
465
G
P
5
497
paull
P
M
2
404
M
A
8
426
A
