G
Gwyn
Hi guys, can anyone tell me with 100% certainty what method the ECU uses to determine there's an injector fault, so it then lights the injector warning light. Is it measuring the resistance of the injector coils, or using some other method?
Is it technically possible to have a blocked or sticking injector, but the warning light not illuminated? My 1.6 Brava is firing on 3. The injector's been changed, ( after which the warning light went off) , the plug is sparking on the defective cylinder, disconnecting the injector loom and spraying easy-start into the air inlet makes it run on 4 for a few seconds, so it's fuel and not a stuck valve. I've checked the injector loom to the ECU, stripped the ECU and checked that the 4 injector trigger transistors are OK, and their connections to the edge connector are OK.
Any info gratefully received!
Thanks,
Gwyn
Thanks,
Gwyn
