Hi All,
Since taking ownership of the 500F, I wanted to replace the battery earth cable which is currently located under the bolt which anchors the left fuel tank strap. Result was the anchor bolt just spins. Upon investigation the nut in the footwell which is bolted to and which I expect should be welded to the body is not.
So the options I see are:-
1. Try and get into the footwell and tack weld a nut, but the concern is the metal there looks relatively thin so wouldn't want to blow a hole in the panel
2. Just Nut and bolt it with a captive Nut
3. Use a Rivnut through the existing hole
I would be appreciative of any comments if anyone has experienced the same or thinks I am missing the obvious. Let the voting begin
Thanks all
Barry
Thanks all
Barry
