Motorhome based on Ducato X250, Battery light on dash.
I have a Bessecarr E520 2008 motorhome, and have a very annoying fault that you might be able to help me with. My Cab battery was prettty flat, and I Started the motherhome anyway, it started, but the Alternator failed. New alternator fitted, but I still have a battery light on the dashboard, and my hab battery does not recieve charge from the alternator. Vehicle battery charging fine. Alternator output on D+ is solid 14.4, and the wire that comes into D+ has 8.4V with ignition on (I'm assuming a volt drop over warning light)
Where does the motorhome get the D+ signal from to activate the split charge relay? and is this on the back of the fuse panel? When plugged into mains, the hab battery charges fine, and if I select the Cab battery on the control panel, that charges fine too. It looks as though the control panel no longer can see D+, and therefore does not know if the engine is running. Could I have blown something? I have checked every fuse and relay in The Engine Bay, dash, and drivers side areas, and all are fine.
