Dear Members,
Let me write a few words about our van.
Its a Hymer 644 Campervan based on a Fiat ducato mk1 from 1992. Its a 1.9TD diesel engine.
I just installed a tracking device but it has some options I cannot use currently as I need advice how to get the device connected.
The tracker can shut of fuel if the provided relay is connected to the fuel pump as show on the picture. Unfortunately I do not know where is this line going.
Where is the fuel pump +12 or which relay is operating it? Circuit breaker on the pic is 12v/40A. If there is a relay for the fuel pump I would cut it and install the relay from the tracker here. Or is it better to cut the feed which goes directly to the pump as shown on the pic?
Fuel sensor is just one wire... where to put? Connect to the dash? To + wire on the instrument?
(Calibration is made on the tracker unit itself)
Orange: is there a horn relay to connect a +12v signal? As this orange wire is very thin I do not think it can handle the current which needs to sound the horn. So would be better to feed the horn really with +12. Or may I buy a separate relay and connect the output to the horn directly?
For this output signal what about if I want to light up some lights like the turning signals? are there any options to do that or for this I have to buy some diodes and an other relay and feed the lights over the relay?
