Tom Hughes
Today my 1998 ducato 2.5 diesel motor home cooling fan started running when the van had been idle for 24 hours
Thanks Anthony, that's really helpful. Very reassuring tooHi Tom
Fan arrangements evolved over the years so I cannot be certain what you have fitted. The most likely arrangement has two fans directly switched (i.e. no relays) by a twin thermal switch screwed into the radiator low down. The switch comes electrically after the fan, i.e. it is the "earthy" side that is switched. One fan is meant to cut in at a certain temperature, and the other comes on as well if the temperature climbs even higher. If one of the internal switches has failed it would give the symptoms you describe.
These thermal switches are not overly expensive (say 15 Euros) so renewing it would be an easy first step. You will need a spanner with 29 mm jaws, and maybe a large cork to stop too much coolant escaping !
Another possibility is that the wire from the fan to the thermal switch is shorting to ground somewhere.
I should have said I have the two fans but after that I simply don't know what type of connection is used in this model. I better figure it outThanks Anthony, that's really helpful. Very reassuring too
Just some additional information here . As your van is only 2 years older than mine , it is possible you do have relays mounted , in the engine bay . Now if fitted , they will be inside a small black box , actually mounted to the top nearside fan shroud .Today my 1998 ducato 2.5 diesel motor home cooling fan started running when the van had been idle for 24 hours
Thanks for the info. We've temporarily solved the issue by removing the cable to the problem fan a few minutes after we stop. So far there has been no repeat of the problem. So we will bring it back to our regular service guy when we get back
I have the exact same problem myself todayThanks for the info. We've temporarily solved the issue by removing the cable to the problem fan a few minutes after we stop. So far there has been no repeat of the problem. So we will bring it back to our regular service guy when we get back
no idea where to go from here,
