I have a 2017 build Ducato 2.3l 180 Multijet with the Comfortmatic gearbox and need to change the clutch fluid.
Multiscanecu has a 'clutch bleed' function for the gearbox. Am I rights in thinking that I open the bleed nipple (photo below) by turning it half a turn and then use Multiscanecu to run the bleed program? Has anyone simply done a pressure bleed?
I've done a few searches and some Ducato's have a retaining clip on the hose that you release then pull the hose out until it clicks then gravity bleed. I'm guessing this only applies to traditional clutches.
Any guidance appreciated.
