Hi, new to the group so apologies if this has been covered in detail and I’ve missed it. Ducato 160, 20k with clutch slip in higher gears around 2000 revs, I’ve read that the extra torque can cause this and so on but as with most forums no one seems to come back with a definite answer on how they fully rectified the problem. Is there a brand of clutch plate which seems to outlast the others? What parts definitely should be changed and does this include the dual mass flywheel? Planning doing work at home, how long should the job take and is there job sheet available anywhere to explain the correct procedure? Thanks in advance for any help
