Hello,
I recently bought a 2.0 JTD Ducato with the problem that at random intervals (between 10-100km) it would just go out with the red injector icon flashing on the instrument cluster. Then the engine can be started again after ignition on/off and a differing length of time (approx. 0-5 minutes) and you can continue driving normally for another 10 and 100 km.
I've already looked at the obvious problem areas (ground strap to the body, feed pump, diesel filter) and couldn't find anything. I replaced the ground wire just to be safe. I then got a USB interface to read the Ducato, unfortunately there was nothing in the error memory that would help me in any way.
- P0380 Glow plug/heating circuit A malfunction: Probably worn glow plugs, in my opinion not related to my problem
- P0110 intake air temperature circuit malfunction: in my opinion the error should not cause the engine to stall
- P0101 Mass Air Flow Sensor/Air Flow Meter - Range/Function Error: Occurred together with P0110, therefore not meaningful. But could the AFM theoretically cause the engine to stall?
- P0148 3 piston deactivation: I read about it on the internet, this is about the deactivation of the 3rd piston in the high pressure pump at idle. But in my opinion it shouldn't cause the engine to stall
Unfortunately, it is not clear to me exactly when these errors occurred, because the mileage of 190,000 km stored in the ECU is incorrect. The KM counter in the instrument cluster reads 230,000 km and the errors occurred at 192,000 km, which cannot be correct regarding the value stored in the ECU.
Other: At idle speed, the fuel pressure was 300 bar, is that enough? The boost pressure was exactly one atmosphere and didn't change when pressing the accelerator > Broken sensor? But shouldn't that actually generate an error in the ECU?
Hoping for some help, thanks...
