Hi all any info on my problem would be grateful
I have a ducato 2.3 multijet 2009 my problem is I keep losing pressure on my clutch pedal. I have checked around gearbox to see if slave cylinder leaking and don’t seem to be also checked all pipe work and master cylinder, no leaks but do seem to be losing small amount of fluid. The peddle slowly works it’s way down until the peddle starts to stop down, when I back bleed it it’s fine for a few miles then back to the floor. I have noticed the fluid is quite cloudy and not clear but have now replaced all fluid but no better. Also I have a slight crunch when changing to 4th gear unless I double clutch the peddle and goes in fine then !
Just need to pinpoint the problem
Please help
Please help
